savage 25rtr just wants to take off when i start it
roozy
after 2weeks of not touching it now that i want to start it it just has way too much throttle...but the carb seems to be closed and the idle is all the way down (clockwise) to bring it down right? only way it will stop is if i hit the brakes and then if i gas it a little it will just shut off.
If nothing else, set the idle back to 2mm and reset the HSN & LSN back to factory setting and start tunning from there, you can't go wrong there since it will run, but be on the rich side, do you have a temp gun??
ya o hjave temp gun ..does 1 turn = 360degrees or 180?
hey , i had the ofna force 25 before, that problem was sometimes (very often) caused by the back plate rattling itself loose, regardless of if you loctited it or not before, take it out, and check your backplate... i blew an engine because the damn thing kept comming loose, and ofna wouldnt send me a new one regardless of me having a receipt and sending the blown motor back . .. and now they have discovered its a problem , i could have told them that in the middle of the summer, ill never buy an ofna again.... sorry for the rant , check the back plate, the throttle control on the radio , and the linkage also
