RustyUs
Military Veteran
RC Showcase: 8
- Pennsylvania, USA
- Racing
Since the question came up recently on another thread, and I did not see any specific thread on the subject.
I know what my normal/cut off temperatures are and how/where I go about getting them. I've always tried my best to not let my motors go above 180°F (82.22°C) even though Castle Creations stated early on for their brushless motors not to exceed 200°F.
On Castle Creation's website, they now have this:
From Hobbywing on the subject:
It's important to consult the manufacturer's specifications and guidelines for the motor, ESC, battery, and other components to ensure that you stay within their recommended current limits. Additionally, monitoring the temperature of these components (Keep ESC and motor temps UNDER 200°F, preferably 180°F or lower; LiPo batteries should not exceed 130°F) during operation can provide a practical indicator of whether excessive current is being drawn, as overheating is often a visible symptom of this issue.
**It is always useful to have one of these infrared thermometers on hand, they are specially designed for use with R/C engines, motors, battery packs, battery chargers, electronic speed controllers, as well as hundreds of other applications. To use, simply aim the infrared thermometer at the target and press the measurement button to quickly and easily display the surface temperatures.
What is the ideal temperature of ESC and Motor? - Avoid overloading your gears.
6 years ago Updated
The most common reason for your ESC / Motor damage is found by "overloading"
It is hard to accurately check the "load of a vehicle system, but there is a simple method.
Measuring the temperature of ESC and motor.
If the ESC temperature (measured from outside at the hottest position) is over 85 degree (for low-cost thermal instrument with low accuracy) or 90 degrees (for high-cost thermal instrument with high accuracy), or the motor temperature is over 90 degree or 100 degree, your system configuration must be changed immediately that a load of vehicle is too heavy for your ESC or motor.
In such a case,
change your gearing ratio by using a smaller pinion or bigger spur gear by one. Check the temp again after running a few laps until you find the perfect ratio. "Stock gearing" does not mean your system with upgraded electronics works perfectively.
Airplane / Heli
change PROPS SIZE, by sizing down to smaller propellers. timing set to 0, Reduce voltage, Check the temp again after running a few minutes until you find the perfect size.
FPV
change PROPS SIZE, reset betaflight, no timing, Reduce voltage, Check the temp again after running a few minutes until you find the perfect size.
