Ryft system build
partsmgr
RCTalk Qualifier
Lifetime Supporter!
Military Veteran
Portland, TN.
I am going to build a Ryft and am thinking about a castle system for ESC and motor. Any recommendations here for a solid setup? I am thinking 3s or 4s with the 2 speed trans.
We went with the Tekin ROC412 HD 2300KV motor and the RX4 and I used a Hitec shift servo, but I had to design and print my own servo saver for it. You can see the build here
https://www.rctalk.com/forum/threads/axial-ryft-build.133765/
Based on Kevs build if you wanted something comparable from Castle Id say youd probably want a Mamba X / 1412 2100Kv combo and then just gear it down a bit to start and tune for temps. That combo is for the 3mm shaft version of the motor but they also offer it in a 5mm shaft version as well.
Thanks for the suggestions, guess I've got some research to do.
When you put the shift fork in the transmission, make sure you install the shift arm on the side of the fork with the counterbore in it. I missed that and it took me 3 tries dismantling and reassembling the transmission before I caught my mistake. It's not called out in the manual AT ALL.
