Give the slipper adjustment nut on the spur gear a half turn or so and run it. Changing to a more aggressive tire puts more strain on the drivetrain, so your slipper is just trying to protect your rig, and working a bit harder now. Tightening it will however send some of that strain back towards your drivetrain components. If you changed your tire diameter, you changed your final drive ratio. You should keep an eye on motor temps. Going above 160°F is getting into the danger zone.
My advice would be to drive it til something breaks. You might break some A-arms, turnbuckles, shock shafts, shock caps, spur gear, or any number of things on it. Ya never know. You might go ahead and grab some RPM arms for it. They are pretty cheap and fairly indestructible.
Stay away ftom aluminum arms, or aluminum for anything that is hanging out there and can get bent, or transfer a hard hit to a weaker component. Plastic parts flex and absorb impacts. Aluminum... not so much. But aluminum uprights, steering knuckles, hubs, bulkheads, etc are typically good upgrades.
