Savage SSX
- Racing
Hey all I think I have a stumper, My K4.6 HO on my savage is running exceptionally hot.
The first time I tuned it "for the best throttle response" It ranged from 350 - 370 degrees.
I figured that was a little hot as the fuel going into the engine was actually boiling. So I took the motor completely apart and cleaned it out and put it back together and the temps stayed the same.
So I retuned it and richened it up and got between 310 and 330 degrees. The manual says 250 degrees is tops so I reset the motor to factory specs and even richened it out a little more until it started to spit fuel out of the tail pipe and I got the temperature down to 285ish. Keep in mind the motor ran like crap on this tune, it was getting way to much fuel.
I put two different pipes on it and replaced the seals thinking perhaps an exhaust leak was the problem but I noticed almost no difference in temps. I cleaned the air filter with no such luck. Then I thought perhaps there was a drag on the car like the brakes were sticking or something so I loosened up the brakes a little and oiled what I could but still the temps are nowhere near the "high mark of" 250.
Anyone have any ideas? I am running blue thunder 20% nitro.
