running batteries in parallel
craig911
Bristol, England
hey guys,
I run a 6V in the savage and a 4.8V in my tamiya TGS
while i was in the tub i had a thought of using both of my 6V hump packs in my savage. also could if anyone has some info on a external radio/battery box that would be appreciated
i did a little research on this but wanted your input
mainly due to combat high current/amp draw from the servos/lights and also longer run time before charging. (primarily to combat voltage drop/brownouts)
i tested it out using a voltage tester and using a Y cable got 6V from dual packs
To reiterate i'm thinking of parallel so 2x6V 1500MAH = 6V 3000MAH
Not series 2X6V 1500MAH = 12V 1500MAH
also doing some research i should be fine charging both packs in parallel
so charging, instead of being on charge for roughly 7 hours =1.5A on my multi charger ( RX TX glow stick )
i can put both packs on over night for a 15 hour charge so there ready when i need them on a planned day out etc,
as my charger does not switch to a trickle charge when the batteries are full it also means that i can charge my batteries overnight without the risk of over charging and damaging the cells
what are your thoughts on using a dual 4.8/6V hump pack
my thinking on this was more on if you have lots of lights on your rig etc so less work for a single battery pack to do and a more consistent voltage under load
so any discussion, info ect is appreciated
(image source http://www.zbattery.com/Connecting-Batteries-in-Series-or-Parallel)
I could be wrong here but I thought the batteries should be the same to run parallel. If you run series, they can be different voltage wise but should be the same mah and C rating.
Sent from my GT-I9300 using Tapatalk
thanks rolex i did a little more research,
both my 6V hump packs are the same both 1500MAH both NI-MH they're both identical other than brand
ones ansmann and the other is turnigy
If that's the case, you're good to go.
A receiver can run between 4.8 and 6V, but it sounded like that might have been the differing voltage on the two packs.
i should have clarified,
i have 2 6v packs and a 4.8v pack
so two 6V packs for the savage and a singe 4.8V for my tamiya
Okay, got it. You can run the two 6V packs in parallel but....
and wait for another battery wizard to comment....
you might have to use a 3000 mAH charge rate rather than 1500 since you double the capacity but not the voltage.
