http://rpmrcproducts.com/products/tools/wrenches.htm#80765
Traxxas Shock Wrenches
for Traxxas 1/10th Scale Shocks
also fits Traxxas “Big Bore” Shocks
Traxxas Shock WrenchesOne of the first notable products created early in RPM’s history was some very unique shock body and cap wrenches. These tools were a must-have in the toolbox if you maintain your shocks. With Traxxas becoming a prevalent manufacturer at the racetrack, it only makes sense that these awesome tools should be made available for the Traxxas line of 1/10th scale shocks as well.
RPM Shock Body and Cap Wrenches are molded from one of our secret blends of nylons, making them a perfect choice to keep those expensive aluminum (or soft plastic) shocks from getting scuffed up from metal tools. How they workThe Body Wrench slips effortlessly over the body of the shock while the hex (or flats) of the shock body seats in an upper recess. The Cap Wrench then slips over the shock cap and with a simple twist of the wrist, the cap easily unscrews off of the shock body. No extra tools required and virtually no possibility of scuffing up or damaging the body or shock cap!
RPM Shock Body and Cap Wrenches are also color-coded blue for easy identification, just in case you happen to have any of our other shock body and cap wrenches in your toolbox.
Tech Notes: RPM Shock Body and Cap Wrenches are designed for use on most 1/10th scale Traxxas shocks including the aluminum “Big Bore” versions. However, they will not work with Traxxas Revo or Jato shocks.
80765 - Shock Body & Cap Wrenches For Traxxas Shocks
Available 07.05.10
Suggested Retail $5.95
Losi Shock Wrenches
Finally, an easy way of assembling and disassembling your shocks without scratching the coating on the shock bodies. Consisting of two molded nylon wrenches, one wrench holds the flange at the top of the shock body while the other fits on the lower cartridge.
Tech Note: These wrenches work with most Losi 1/10th scale shocks. They will not work on 1/8th scale shocks or monster truck shocks such as those found on the LST & LST2.
70732 - Shock Body & Cap Wrenches For Losi Shocks - Discontinued
Suggested Retail $4.95
Associated Shock Wrench
Similar in nature to #70732, these tools are designed for Assoc. shocks. Designed to eliminate scratching the shock body, this two piece wrench set simplifies many aspects of shock assembly and disassembly. One wrench slides around the shock body hex while the other fits snugly over the shock cap. Accept no imitations of the original RPM shock wrenches!
Tech Note: These wrenches work with all versions of Associated 1/10th scale shocks including both aluminum and molded versions.
70781 - Shock Body & Cap Wrenches For Assoc. Shocks
Available 07.05.10
Losi Shock Wrenches
