I was trying to do a servo conversion without watching a video and I took off the shock and the rocker arm and it was really hard to unscrew and the rocker post and the arm all came out in one it was wierd I'm just trying to see if I can pull out or lower that rocker post that's sticking up in the picturewhat are you trying to replace?
Yes thank you I figured it out I had to use the rocker arm screw to screw it in deeperAre you talking about the section above the hex? I would imagine that is a one piece unit. Your only option would be to cut it shorter with a Dremel. Make sure the threads are deep enough first.
the servos are under the chassis. there are two of them.I was trying to do a servo conversion without watching a video and I took off the shock and the rocker arm and it was really hard to unscrew and the rocker post and the arm all came out in one it was wierd I'm just trying to see if I can pull out or lower that rocker post that's sticking up in the picture
