Riddle me this
Status
Not open for further replies.
Another.......
A man is six feet tall, is a clerk at a butcher shop, and wears size 11 shoes. What does he weigh?
Only knew it because every time I look at my resume I think I spelled it wrong. :)
Another.......
Venture to guess...Meat?
Damn I should have had that one, considering I'm a butcher by trade.
That's 2 in a row.
Math time....
75% can be written as 3/4. How would 58 1/3% be written as a fraction (when reduced to the lowest denominator)?
Correct.
How can you arrange four ordinary wineglasses on an ordinary table so that the "foot" (center of the bottom of the stem) of each is the same distance from all the others?
On each corner if it's a square table.
If it isn't, just have all the glasses touching. (arranged in a square)
....or STACKED, one on top of the other.
Stacked is wrong since it will put 1 and 4 too far apart. (I've handed in my worksheet)
Not quite.
They "foot" must be the same distance from from each of the other "foots".
If you arrange in a square, the diagonal distance between the corners would be more than the side distance.
I hand your worksheet back to you.
You still have the diagonal distance being more than the side distance. Square will not work.
Your getting closer.
Ah HAH!! in an equilateral triangle with the 4th glass in the center.
Yes Regis, that's my final answer. If I'm wrong, I'm still locked in at $32,000.
We have a winner!
I will assume you meant to mention that the 4th glass is upside down in the center.
Here is the official answer:
Place the first three in an equilateral triangle so that the foot of each is the same distance from the others as the height of a wineglass. Then place the fourth wineglass in the middle of the triangle, upside down.
Some quick ones....
What can go up a chimney down, but not down a chimney up?
robmob I found your cheat sheet. I think Rolex did too.
We have a winner!
That wasn't my original answer, but when it dawned on me that it had to be upside down, you had already posted it.
Santa, really snockered.
If you're using Google, you're disqualified. These are puzzles, not intended for research. If you look up the answers, there's no enjoyment in them whatsoever.
Status
