Revo is constant issues...
pug
  3. Crawling
The slipper keeps coming loose, I have tried to tighten it down tightly so it would stay. Then the engine's one way bearing decided to start slipping, I have no idea how the one way bearing in an Axial .32 works, it's not a normal one way bearing. It's only the Traxxas nitros I'm having problems with, are they just poorly built?
Revos are an engineering piece of art, and from my experience are very durable trucks.
The slipper clutch should have a lock nut which you tighten, how is it possible that a lock nut keeps coming off?
Is the OWB in the EZ start system that is slipping?
Bro just convert it to electric as I did. Get an E-Revo tranny and your good to go!
No. Electric is incredibly boring to me and it's not right to electric convert a nitro imo.
No EZ start, it's an Axial .32, the nut does keep coming loose.
Lock nut should be accessible from the outside, no need to take the tranny out?
It's very hard to access due to the incredibly large engine.
Check the lock nut is actually locking, I am not sure, maybe even apply some thread lock.
When I had the Revo, although with a stock 3.3, I have never had any issues with the truck, apart from overheating, due to engine being underpowered when moving such a heavy truck.
It looks tight
Looks and is tight are two different things, when it comes to slipper clutch.
With the Revo on the ground (carpet works best for traction), hold the spur with your finger and try to roll the truck backwards, if the slipper is loose, you will see it slip and truck will move, that will tell you if the nut is loose or not.
If you can't hold it with your finger while rolling, then its tight and problem is somewhere else.
I checked and it is indeed tight.
In that case, what makes you think your slipper clutch is slipping?
It has done this before because the slipper came loose, I have a spare rebuild kit I believe
