The spring broke on the pullstarter, which happend two years ago and after that the truck has just been resting and collecting dust. I am using the THS pipe and Buku clutch.
Is this the new era mount?
If i can just a confirmation that i can fit the LRP .32 with the new era mount in revo.
No, it isn't. That's a one piece mount someone made. Guessing it's similar dimensions to the NE mount though. Looking at them side by side, they appear similar dimensions. His description states it will work with any big block with a pull-start without modifying the arms. Also has some material removed to lighten it a bit.The spring broke on the pullstarter, which happend two years ago and after that the truck has just been resting and collecting dust. I am using the THS pipe and Buku clutch.
Do you know if you have to move the gearbox on the lrp .30 and 32?You don't have to if you use the revo flywheel/clutch/bell, but you do if you want to swap out to 1/8th scale flywheel/clutch/bell. I did that on my BB revo as the smaller 2 shoe couldn't hold up very well.
