3_Stroke_Motor
Does anyone have a good easy way replace a Jato transmission case? I had a nasty cartwheel today that ended up snapping the upper arm linkage that connects to the transmission case. I have already successfully replaced the one side that was broken... In 2 hours. It was a relatively easy fix, It just took a rather large amount of time to do. I had no hang ups or head scratching moments, it was 2 hours of non stop assembly and reassembly. I completely disassembled the back of the jato, all the way up to the engine, with the exception of the steering hubs and arms , which I pulled the pins out and set the assembly aside whole. The shock tower had to be taken out as well as the braking mechanism, which by the way because of the snap, the brake disk was broken in half and I was unsuccessful in finding any remains of it in the dirt. Over all it was a pain in the a$$ to tear down and rebuild. I can't figure out why traxxas would connect a such a fragile essential part to the car to such a deeply implanted part in the car. Luckily it was a very inexpensive crash, 5 bucks for the trans case and 4 for the new brake material. But I digress. Does or has anyone found an easier way to replace this for the future? Something that takes on the underside of an hour maybe??
P.S. Is it possible, or safe to put in a double disk brake setup on the jato? One disk I have found is rather insufficient (and does not last long at all) to stopping this vehicle from a 50 mph. plus acceleration into a turn.
^^Unless you can read Russian or have a translater these are just wierd looking symbols^^
