Redcat SH.18 will not start.. Help needed
2GMitsubishi
Moscow, ID
My Volcano S30 will not start.. I have new fuel, new fuel filter, I cleaned the lines out just to be sure..
My carb settings are LSN 3 turns out and HSN 3 1/2 turns out.
New hot glow plug that tested good and I've got a full charge on my igniter.
Wtf could be the issue?
I've adjusted the LSN a quarter turn at a time from fully closed to four turns open and no where in between did I get a start.
It is a rotary carb
My idle is set at 1mm open.
The engine has a Mild port and polish..
With my SH .18 I always have to turn the throttle trim up to open the gap up to get it started, then trim it back down once it fires up. I presume this is normal though?? I've never used anything else, this is my first nitro car. I set the LSN to about 3.5-4 turns out from memory, at 3 it seemed a bit lean on the pinch test, but that shouldn't stop it from starting though.
It is a rotary carb
If theres fuel flow to the carb. ,it should fire ,is the head bolts tight an the head have a good seal?
An just like Jeff said ,sometimes engines needs a little bit more on the gap!..,My Hyper 21 engine
has to be opened & closed by the transmitter before it will start!..:cool:
Yeah they are tight, I torqued them like a head on an old ford lol.. I am getting fuel but it only wants to start if its flooded for some reason and then it dies once it burns that fuel up. I tried opening the throttle up with the remote while starting but to no avail.
Have you tried it without the filter in case that's causing a problem? Or turn it around in case its directional? Somethings obviously stopping fuel from flowing through, but if it primes OK that seems strange to me.
Yes I am trying it without the filter on. It is priming really well but not igniting. I just got done talking to redcat and they said the stock setting for the lsn is 2 1/2 out not 3 1/2.
I'm running a hot glow plug and 20% nitro.
I just got done taking the tank out and flushing it spotless with nitro and did the same with both fuel lines and the fuel filter..
Tried again after I got it back together and no start..
Honestly if I wasn't almost 500bucks into a $200 truck it would be gone by now.. But I'm in too deep now no turning back.
Got to say though I just found out the best way to clean your nitro is disassemble, clean and reassemble lol
At least its clean now
Mine did the same thing one day. I ran it in the morning and whe I went to start it a couple hours later, nothing. Glow plug was lighting up and I put the needles back to factory settings. Wouldn't fire. Finally in desperation I pulled glow plug and put in a Traxxas 3232X plug. It fired right up! You might try a different plug. Sometimes they look ok on the ignitor but just won't fire the fuel.
