SpeedyBooty
RCTalk Qualifier
- Racing
- Crawling
- Scale Builder
What is the minimum amount of angle that could make my drifts sucessful?, and would i need a gyro or not
Its a rwd conversion for a 4wd drift car, does that make a difference?Practice, slick tires and a smooth slick surface to drift on are my suggestions.
But if you are referring to camber and toe in a wheel and tire, then you might want to read this.
I would think a gyro would hinder you and not help but look it up. Maybe it will help you as I do not use it in my car.
All i really did was remove drive shaft, and 2 front dogbones and modified the c hubsIt could. depending on how you did your conversion. Someone else with more experience than I will have to chime in on the details on that one.
I use a 4WD and have tried it in 2WD and like the 4WD better. There was a huge difference in the two.
Everything makes a difference with drifting as you are trying to control a car that is inherently out of control.
