Primary use is just parking lot ripping with my son. It's 12mm hex. Is there an advantage to buying pre-mounted vs unmounted?
For parking lots, these are the tires i would suggest for the rear:
https://www.towerhobbies.com/produc...HhJc1KKh1hTZUSlRrU4lMbqUOKD5RixAaApRWEALw_wcB
For the fronts, any 2.2 ribbed tire, or even a stadium truck front tire. I run an Associated ProSC10, which is basically the short course version of your buggy, and, i use the Bandito on the rear, and Traxxas bandit fronts (skinnier than the Rustler ribbed) or Associated SR10 (
https://www.ebay.com/itm/2041488420...Ut0Il/lRleNz4dzI=|tkp:Bk9SR9a0iZydYQ&LH_BIN=1) tires on the front, however, the Associated's might be a bit wide for a buggy. I do get the tires and wheels separate though, and glue them myself, that way the wheels match (disclaimer: I do hate gluing tires lol)
These are some of the others i have used.
https://www.ebay.com/itm/1341151469...5/jSGGiXlrGPOIp9c|tkp:Bk9SR_bWo5ydYQ&LH_BIN=1 Not bad on or off road on the front, but, tend to slide on wet asphalt, so turning is reduced.
https://www.ebay.com/itm/3741903582...ny3pSciJjS2WyAg==|tkp:Bk9SR_jWo5ydYQ&LH_BIN=1 Rears tend to wear out way faster than the fronts, and dont last very long (last time, i think i got 6 full batteries out of them)
https://www.ebay.com/itm/1626596737...Dp7Wj44xCf49IKrZo|tkp:Bk9SR_zWo5ydYQ&LH_BIN=1 These dont last long on asphalt, neither do most of the "soft" compound dirt tires.
https://www.ebay.com/itm/3942891842...iLVnFn9rfzoH4zg==|tkp:Bk9SR_7Wo5ydYQ&LH_BIN=1 These are like the Traxxas Bandit fronts, both of which have a tendency to slide on wet ground, and, even on dry ground arent always the best, but, they are ok.
https://www.ebay.com/itm/3342896780...v+PiqSuSTZzedgw==|tkp:Bk9SR6Tcr5ydYQ&LH_BIN=1 These arent too bad, but, the wheels suck, so, since they usually come unmounted, i mount them on better wheels. You have to make sure to read the description carefully though, because they also make them in 1/10TH touring car size, which are smaller than buggy wheels.
https://www.ebay.com/itm/1938487891...59dYgeiWbCR2zsA==|tkp:Bk9SR87pvZydYQ&LH_BIN=1 These seem to be hit or miss, depending on the temperature of the surface they are on.
