WickedFog
Community Leader
RC Showcase: 9
- Terre Haute, IN
- Crawling
- Scale Builder
Introduction
@Lostinthewoods86 sent me this radio for scientific purposes. So as I learn more about it I am going to use this thread to document things I figure out with this amazing radio.
Here is everything you get, and currently, you can grab this radio for around $130 from various online shops and retailers, as well as Amazon.
Description
The RadioMaster MT12 is a pioneering open-source surface radio, and the first surface radio officially supported by EdgeTX, ExpressLRS, and the Multi-module project. Boasting 10 physical inputs and the capability to handle either 16 or 32 channels*, the MT12 is primed for a wide array of surface models, from cars and trucks to boats and beyond. Featuring extensive customizability and a versatile operating system, the MT12 stands out as a highly configurable surface radio, prepared to excel in virtually any scenario.Features
- Available with Built-in ExpressLRS Backpack or 4in1 MPM RF modules
- Featuring a powerful STM32F407VGT6 with 1MB Flash
- Preinstalled EdgeTX firmware
- QC3.0 fast charging supporting 2.0A MAX
- Compact design with excellent ergonomics
- Oversized battery compartment - 2 x 18650 cells or a 2s 7.4v 5000mah battery pack (Batteries not included)
- Standard Nano module compartment
- RadioMaster standardized button layout
- Rotatable antenna
- Customizable base switches or 4 way joystick included
Specifications
- Item: MT12 Surface Radio
- Physical dimensions: 177.8*118.4*207.8mm
- Weight: 480 grams
- Operating frequency: 2.400GHz-2.480GHz
- Internal RF Options: 4-in-1 multi-protocol / ELRS 2.4GHz
- Supported protocols: Module dependent
- Operational current: 160mA for 4in1 / 320mA for ELRS
- Operational voltage: DC 6.6-8.4V
- Operating system: EdgeTX
- Control channels: 16 as standard, ability for expansion 32 Channels (4in1 only)
- Display: 128*64 Monochrome LCD
- Battery: 2 x 18650 cells or a 2s 7.4v 5000mah battery pack (Batteries not included)
- Charging: Built in USB-C Charging
- Firmware Upgrade method: Via USB or SD card
- Wheel and Trigger sensor: Hall-effect
- Module bay: Nano size (RadioMaster Ranger Nano Module / RadioMaster RM 4in1 module / TBS Crossfire Nano module)
Specifications for ER3C-i (Included with ExpressLRS version)
- Item: ER3C-i 2.4GHz ELRS PWM Receiver
- Power supply: DC 4.5 - 8.4V
- Antenna type: Built-in high-sensitivity ceramic antenna
- Wireless protocol: ExpressLRS 3.3.0 pre-installed
- Output channel: 3CH PWM
- Telemetry power: 10mW
- Battery voltage detection range: DC 4.0 - 35V
- Weight: 4.2 grams
- Dimensions: 26.1*18.5*13.0 mm
- Firmware: Device Category: Radiomaster 2.4Ghz / Device: RadioMaster ER3C-i
Specifications for R85C (Included with 4in1 version)
- Item: R85C Receiver
- Frequency range: 2400-2483.5Mhz
- Support protocol: D8/D16/SFHSS
- Output channel: 5CH PWM
- Antenna type: high-sensitivity 2.4G antenna
- Telemetry power: 100mw / 20dbm
- Weight: 5.7 grams
- Dimensions: 31.0*18.5*13.0 mm
EdgeTX Operating System
Preinstalled with EdgeTX, the MT12 has cutting edge software fit for its class-leading hardware. RadioMaster works closely with the EdgeTX team to develop new features and optimize the user experience for surface models. We will continue to contribute and support projects like EdgeTX, ensuring the concepts of open standards are carried forward.
For more information, please visit https://edgetx.org/
Available with ExpressLRS and 4in1 Version
In addition to the popular internal 4-in-1 Multi-module, the MT12 is also available with an internal 2.4GHz ExpressLRS (ELRS) module. Designed to provide reliable long-distance control, super low latency, and high refresh rates. ELRS is a revolutionary open-source protocol taking the R/C industry by storm.
ExpressLRS Version
ExpressLRS supports ultra-fast response modes for seat of your pants racing or super long range modes for pushing the limits of your adventures.
4in1 VERSION
One remote to control all of your cars. The 4in1 internal RF system has protocols, for many popular brands of cars and receivers.
Click here to visit the list of supported protocols
For some quick tips when you first get your radio, you can check out some of Radiomaster's videos here:
https://youtube.com/playlist?list=PL_iw2u3UZ8R2aJE5DHvJXBh6vn-yl6Pi-&si=8sM4q7t_6vmt6pvg
Before You Buy
There are two options for this radio. The ELRS version, and the 4in1 version.
The ELRS version is for use with ELRS receivers. This protocol is designed to provide reliable long-distance control, super low latency, and high refresh rates. Great for racing applications.
The 4in1 version of the radio has an included module which uses the most popular protocols for today's RC radio systems. The 4in1 version will bind with Traxxas, Spektrum, Flysky, and many other brands of radio system protocols, meaning you can use this version to control nearly all of your RC's, without having to swap out the receivers.
If you buy the ELRS version, you can also grab the 4in1 module which will attach to the module port on top of the radio.
This will allow you to choose between the ELRS module, or the attached 4in1 module to have the best both versions of this radio has to offer. However, with the ELRS version of this radio, you will be limited to only 16 channels. With the 4in1 version of the radio and an additional 4in1 module, you can pump this radio up to 32 channels. Why anyone would even need 16 channels on a surface radio is beyond me, but OK.
If you buy the 4in1 version, you can also buy ELRS modules to take advantage of the improved range, low latency, higher refresh rates, etc.
If you want to read up on any other info about this radio you can check it out on Radiomaster's website located at:
www.radiomasterrc.com
