R/C Car Cleaning????
REVOTMAXX.18TM
What do you guys think, (Recomended Denatured alcohol)-And standard alcohol which is a lot cheaper, I use an air comp. also, just want to know what most of you guys are using?????????????Thanks!!!
jetmechG550 said:
Simple green and water, occasionally use DA. Isopropyl leaves a slight residue where as Denatured does not. SG cut 1:1 or 2:1 works great.
Doesn't simple green 50/50 leave a residue? Wouldn't there be a soapy film left? I also use my air compressor also.
No. After a heavy race weekend, I remove electronics and then blast it down with simple green and then hose it off a garden hose, then blow it out with my air compressor. At the track I'll use simple green in a squirt bottle set to stream and then hit it with water from another squirt bottle set to stream so I can direct the spray. Someone usually has a compressor or one at the track to blow it off. The big cleanings usually get a WD-40 bath and I re-lube all the joints, axles and bearings.
I'm about the same as everyone else, but I use denatured alcohol on metals, and simple green on plastics. You can use simple green on metal also.
I just use a little ration between simple green and water. Usually so that the solution is a light green-mild green.
