quick question.
beason
Bash, Fix, Repeat..
Webster, TX
i just got this revo, and it has the built in charge jack. well, i dont have the converter for it to go to my peak charger. I want to buy one (i had one but can't find it.......) but i dont know what it is called... I need one end to be ether "tamiya" or "mini tamiya" and the other end to be a female version of a servo plug...(like whats on a failsafe.) I'm not sure on the name of this one...
anyone know where i can get one of these? i would really like to know what its called so in the future ill know what to look for...
thanks for your time.
Do you have the wall charger for it? If you do, cut the mini plug off the wall charger and solder it to the tamiya connector. Double check the connection with a voltmeter to make sure you have the correct polarity.
nope, got it used with no charger... there may be something in the rest of the stuff coming with it but i havent gotten everything yet and i wanna drive it! lol
that doesn't look like it candy, i need the smaller end to be the 3 pin female version of a servo plug (futaba?) same end that comes on the stock charger that comes with the revo. thanks for the try though
edit: found it!! thanks for the link candyman!
here it is.
http://www.3dhobbyshop.com/detail.aspx?ID=738
yea i saved that websight they seem to have alot of good cheep stuff. I'm getting a new charger that uses the banana ones, so ill be buys a bunch of them....
