question on tower trainer 40
offroadrcguy
RCTalk Qualifier
  3. Crawling
  4. Scale Builder
  5. Flying
just purchased a tower trainer 40 from facebook to get back into flying. i have a question. is the tower trainer 40 designed so that it levels out of a turn without any input from the alreons or do i have to manually do it. thanks
wish me luck on the maiden.
The v shaped wing will self level. But not as quick as you may need. Good luck.
Remember when the plane is coming toward you point the aileron at the low wing to level out.
Maybe a simulator or a buddy box would help for the first flight.
alright thanks. @Tunedpipe. i have a simulator but i dont really use it any more because its old. i already have flown several planes before so flying a trainer shouldn't be that hard right? but thanks for the tip. i will definitely purchase another one just in case.
If you have experience already then that's good.
There are also airplanes out there that have the GPS system that is designed for training and has a land by itself option.
