beason
Bash, Fix, Repeat..
i keep ripping the shock ends off my revo. It used to be the rear of the truck, now the front is doing it as well. after a hard bumble or cartwheel the shock end has pulled off and i normally loose the spring perch. this last time i ripped the same one i just fixed off in under 5 minutes. so its not wear or old plastic.
i have rpm arms in front and tekno ext in rear, p2 rockers, traxxas hollow rods with one spacer on each end and the rods in the middle hole on the arms.
has anyone seen this issue before??
i also noticed there are 2 holes for the upper arm pins in the front of the truck. mine are in the top, could moving them to the bottom help?
thanks in advance!
thanks in advance!
