Thank you for the reply. I have just tried that and still no joy. I have tried the plug 1/4 turn in , 1/2 turn in .Your flooding the engine too much. Take the glow plug out and pull the engine over to clear it out. Check plug for orange/yellow and Put the plug back in DO not tighten. leave 1/4 turn loose. Prime the engine 3-4 pull's and block the stinger on the exhaust to force fuel to carb. attach glow driver on and then try and start 2-3 more pull it should pop off.
I agreed with this. Sometimes the screws got too tight at the pull starter or the spring is too week and need to rewound it back a couple of turns to give it more tension. I have rewound many pull starters ? not my fault, I didn't break them, I only fix them.Almost there. Try loosening the screws that hold the pull starter on. You may have to remove the pull starter and clean it out and pull all the way till it stops a few times.t. Use wd-40 and pray it clean and put it back on. Turn the idle screw 1/2 turn in. Now try and pull starter with glow plug back in. before putting engine back in. It should pull and retract back in with the glow plug in. IF not then I suggest a new pull starter or a sullivan tiger drive system.
http://www.beatyourtruck.com/prodreview-TIGERDRIVE.html
I think you are right, it is not a vertex, it is an older Force .12 engine.The OP has tried all my suggestions. I gave them already. Has anybody looked at the pictures? It's not a vertex .15 or .18.
