- Bomb Pop Island
- Racing
Super nice servo
Love my Power HD servos. All my rigs have em. I put a GTS-5 Pro (low profile) in my Talion. I save all the fancy cases tooSuper nice servo
Haven't noticed any difference using 8.4v. I haven't used glitch busters. I have a couple of them. They do keep the ESC from browning out under high BEC loads.Thanks, 332. Notice the servo David is showing has a torque rating of 277in at 8.4V. Running it at, say the 7.4v HV option reduces the torque rating to ~250in, give or take? 7.4v is the highest option I've seen on my ESCs.
What is the trade off? More power battery voltage bleed-off to operate the servo? Resulting in less run time? Or is it even noticeable? If there is a voltage sag in the battery under acceleration? Is a 8.4v HV servo more likely to glitch than a servo powered at 6.0 or 7.4v? Is using a 'glitch-buster' to minimize voltage sag at the servo advisable under HV use? -AC
Only thing I found with a quick search.Does the Power HD B5S have spare gear sets available?
That's quick! Power HD! You won't have to wait on the servo to get on the power out of the corner.
I don't know when high voltage (HV) servos came to be, but I'm sure servos with maximum speed/torque values sell better. Not everyone is going to think about their ESC's BEC output when making that next servo purchase. Those in the know... know.My battery power is primarily 2s with 100-130C ratings. Do have one 3s in the inventory. Running 2s with a high C-rating tends to hold the voltage well dropping to ~7.9 to 8.0v for my sessions. Sticking with a standard-v 6.0v servo or, at most a 7.4v is the better option for me. On 3s, might be able to power up an 8.4v if an ESC has that option.
For my purposes, thinking a HV servo and ESC with 8.4v BEC is more useful with battery packs 4s-8s range? Is that correct thinking? Thanks for the good useful info. I'm smarter on HV servos now. -AC
Without opening up the servo; seeing what's inside... those B5 servo gears might work. I'm not going to dig to find out what the differences are between the B5 and B5S servos. I'm sure you won't need a spare gear set for years. Keep 'em bookmarked, I guess. Go give 'em racin' fellers heck!Only thing I found with a quick search.
https://www.ebay.com/itm/3862128246...-89t1-ptJRyVxuTxRvd_LB3CFQ-e9Xqhxu1Kmcs&gQT=2
