MustangMan
So I'm getting back into the hobby after a two year hiatus while I built a Cobra replica and just had more work than I could deal with at the office. Anyway, I dug my HPI MT2 out of cold storage and proceeded to try and get it running. So I put fresh bats in everything, check the servos and radio, filled the fuel tank and shoved the Roto-Start in the T-15's back side.
She lit right up and settled into a nice idle. I grabbed some throttle and, while the engine revved up cleanly (so I thought) the truck barely moved. I thought maybe the clutch shoes were stuck or perhaps the slipper backed off or even deteriorated in storage. I proceeded to break the truck down, pull the slipper out (it was fine), pull the clutch bell (it was fine), inspect the clutch shoes and springs (they were fine) and didn't see anything out of place so screwed it all back together.
I fired it up again and still no change. So, I finally reset the needles and started it up again and STILL no change, matter of fact it idled worse and was spraying fuel everywhere it was so pig rich. So I started leaning it out, first an 1/8th of a turn, and then started just cranking the screw in. It finally cleared out and started hauling ass. My "DUH" moment? Forgetting just how much Florida weather (heat and humidity) effects the way these things run!
So, let's hear your "DUH" moments! Leave the pipe plug in place trying to crank your engine over? Put the clutch shoes in backwards? Or maybe you forgot the window masks on your first paintjob (all DUH moments of mine in the past I have to sadly admit)...
So, lets share in my pain (or stupidity, I guess it depends upon which side of the fence you're on!)
Mark
Mark
