I re-designed my concept. Cison does make an output d-shaft that you can easily bolt on different gears. It makes sense to me now to revamp the transmission concept so that I can use better clutches than what they offer (which in no way I think are strong enough). With the new design, I can use 3-4 shoe 1/8th scale. If that doesn't hold, I could make a custom bell, or possibly use a 1/5th scale setup, as the bell and clutch would be on their own shaft that would have a d-cut on the end to accommodate a set-screw gear. This way I can play around with FDR's to no end as well by swapping gears on the engine output shaft and the clutch shaft.
I'll need to get a custom shaft for the clutch/bell setup. I'm contemplating a mini-lathe, well I really want one anyway for so many reasons. I was looking at this one:
https://www.amazon.com/VEVOR-x14-Benchtop-Variable-Precision/dp/B09FDVMYXS
Not sure, but I think it'll be fine for making small shafts and stuff.
I did a bunch of math, based on the top speed of the Kyosho Mad Crusher (40mph) from which the transmission came from. Assuming the diff ratios would be similar using Savage diffs, and based on the KE25 rpm limit of 33k, the Cison is 11k, the Mad Crusher using 2.5:1 reduction with the chain/sprocket setup, the car would have a top speed of 33mph if I had a 1:1 ratio between the engine and trans. To get this where I'd want it, probably need to do about 1:2.5 ratio, giving it a top speed of 83mph, which would be decent for a 1/7 car. Maybe 1:3 would be best even.
I have yet to see the engine in a vehicle, but I do know a few are working on it. I'm kinda hoping JohnnQ90 swaps his Toyan out for the Cison (he has both the OHV and Flathead versions already) so we could all compare. There is no doubt from the reviews coming in that the Cison is a vastly better engine, with far greater throttle response and power. It's advertised at just under 5hp. I'd really need to keep the car under 15lbs to make it comparable to my nitro cars. Really, around 12. Possible? The engine weighs 5.5 lbs by itself. Radiator .17 lbs, and so I'm thinking let's go with about 6lbs of engine/radiator, tubing, mount, etc. I believe my current 1/8th scale rolling chassis weighs 3.5 lbs without the engine/exhaust. Call it 4. This chassis would be longer, a bit wider, I think though at most, half a pound more of CF. I'd still run 2.5 on the bottom, 2.0 on the top plate. Let's say 5 lbs then to be on the safe side. Then it's just the difference in weight between the trans/diff combo and the alloy Jato trans. That would be at most half a pound, if even a quarter. I think 12 lbs might be realistic actually, including likely heavier wheels/tires. This gives it a power to weight ratio of .4 compared to .5 for my big block nitro car. To achieve the same PWR I'd honestly have to get the car to 9.6 lbs.
Maybe that's not a huge deal. The V8 would have vastly more torque than a single cylinder 2 stroke. That said, it would be a pretty mean feat to get the thing under 10 lbs. I'd still use a Jato fuel tank, so that'd be equal there. What would help is finding lightweight wheels/tires. Right now, there are very limited options for this scale, and virtually zero drag options. I'd be using some shaved down ProLine Menace belted MT tires for the rear, and DT Banditos for the front.
Then, there's the options of power adders, a whole territory that is only being explored right now with these mini V8's. Turbos. Nitrous. It's all being done as I write. That would of course really change the equation and who knows how much.
I'm still tepid on this whole thing, but I really cannot stop thinking about it. I think what I'm going to do is 3D print the engine, radiator, various parts I don't have, to prototype it out. I do already have pretty much every other part already. I have the trans, bell, clutch, fuel tank, arms front and rear, shafts, brake, etc. Maybe I'll grab a body and prototype the entire thing over the Fall/Winter. I see the Cison V8 is dropping in price some too with some discounts/specials. There are some other V8's on the way in the same scale from what I'm hearing too. I think I'll have a roller that I can drop whatever powerplant in I want.
Of course I did think of a name/livery if I somehow pull it off...
