Portal axle help
Zjrs27
Hi, i bought some kyx portal axles and my front axle spins smooth and freely going forward but if i go to spin it in reverse it binds and locks up.... Can anyone help as to why? Came pre assembled, all I did was mount up to it never opened anything up inside
dont touch axels . call kyx or E them ask them to fix.. not sure what type of warranty they come with
I had some preassembled Wraith axles and it did the same thing only when they were by themselves because the gear that attaches the drive shaft to the differential pushed backwards and jammed everything up. Having a drive shaft on there stops it from pushing in the axles as the drive shaft gives it no room to slide forward.
What was the issue? I am having the exact same thing happened with my rear axle. It's the portal set from KYX for the Capra.
[automerge]1625871782[/automerge]
