picco problems
mckinney03
lafayette oregon
ok after installing the ofna bb pipe. my picco .26 does two things it starts real hard(it floods real easy) and once it starts and is up to temp, i do a couple wide open passes it just dies whenever i stop...or it idels really low then idels back up to normal..95% of the time it just dies.....o ya and now I'm gettimg alot of air bubbles in the gas line......i have tryed tunning it to the tuning chart but no luck can u help? thanks guys
its got an air leak between the motor and the end of the pipe. so somewhere around the header. thats what i think anyway, if I'm wrong someone chime in
Another thing you might want to try is turning your idle screw in maybe a quarter to half of a turn. If it still dies then you know for sure you have an air leak somewhere. Hope this helps, Steve
put old pipe back on and test. if new pipe is causing problems reset all needles to factory and tune. if you can't get a tune good then take to LHS and see what they think. pipe could be faulty at the end of the day, but you have to exhaust all other options before you waist your time taking the exhaust back, incase it isnt the exhaust thats faulty.
