Orion ESC Limit?
GilBeQuick
Anyone know what the motor limit is on the Team Orion Flash Micro Electronic Speed Control?
Thanks,
Bryan
If anyone was interested I found out that the Flash esc will handle the big block modifieds as well as the normal micro motors, and handle 4-6 cells.
Flash Micro ESC
Team Orion Flash Micro ESC
To control the power the the Team Orion Flash Micro ESC is the ideal choice. The flash is using the latest high frequency technology with smd fets and components. With possibilities to go forward, brake and reverse, it makes all Micro cars easy to drive. The small size allows the use of lower bodies and lightens the overall weight of the car !
Really strong, really thin and of course also waterproof !
Equipped with universal plug to make it able to be used with any radio equipment.
Number of cells : 4 to 8 4,8 Volts to 9,6 Volts
Current : 5amps continuous, 25amps peak (2 seconds)
Weight : 30gr (including wires)
Size : 38mm x 33mm x 5mm
Brake : 14 amps
BEC : 5 volts, 1 amp, ultra low loss
The Orion Flash is their ESC for the HPI Micro(meant for the micro motors like the Elite Stock & Elite Mod, not even sure if it can handle the Big Block)
man not much out on this esc i spent 20min googleing it...even found a pdf of the manual nothing about motor turn or size??...........interesting thing though, the manual says its waterprof but the under reasons the warenty would not be covered was water damage :) the best i could find is above.........good luck
gil be quick all right :) beat me with my investigation
later
It can handle the speed 300 versions graupner/chubby/baja but if you ever want to upgrade it the best is the novak spy
