Ofna 28 Engine In Jammin X1
MR4X4KING
I have more toys than I know what to do with.
Military Veteran
Coaldale PA
Need Some Help Have A Jammin X1 With About 1/2 Gallon Ran Fine Then Locked Up Took The Back Plate Off And The Piston Is Off The Crank And The Piston Hole Is Broke Any Ideas
Can you post any pics of this?Sounds as if the engine was Hydrolocked and trying to start it broke it.
Have Pic Not Very Good
What Do You Mean Its Says General Chaos
Uh NO it was originally posted in the RCTIRE FORUM.I caught it and moved it to the General Nitro talk forum.
I Guess I Was Not Paying Attention And I Sorry For The Mistake
As You Can See I Am New Can You Tell Me How To Insert A Picture
Yes It Was Running Down The Street Stopped Took Off Turned Around Pulled Throttle About Half Way Then It Shut Off
AND NOW WHAT YOU SEE THIS IS MY STEP SONS CAR THAT HAS BEEN BROKE IN AND SET UP AT THE LHS
Well then I would check the rest of the engine for grooves that may have been done to it. If the engine is decent it may be worth replacing the piston and sleeve. If not, I would looking o upgrade and also buy some zipties for your air filter so it won't fall off next time
Air Filter Is Zipped Tied On Never Fell Of ALL THE LTTLE PIECES WHERE IN THE BOTTOM
What do you mean? did the aire filter fall off or not?
No It Did Not Come Off I Answerd Yes To The Regular Maintence Sorry
Well regardsless the engine needs to be either rebuilt or replaced. Sounds like the engine isn't worth it..honestly.
