Somehow I skipped these, so I’ll just throw them in right here.. Not a big deal, and this is just some boring fundamentals type shiit anyhow lol.. Not even necessary IMO on a fresh build with brand new parts, as the plastic, AND pillow balls are super smooth, with nearly zero porosity yet… But I DO, do this within my regular maintenance. Just run around the inside of the ball cups, and the inner contact point (cup area) of the steering block with your graphite pencil, until it’s all shiny, and grayish.. Do NOT ever use grease, or oil to lubricate your pillow balls lol.. Teflon, Graphite, or NOTHING. I also cut out small circular decals from old sticker sheets, or the portions that are in between the decals I am using, to cover the holes in the pillowball nuts. I’m well aware that the backside is “exposed” to the elements, but if your preload is what it should be, then that’s not ever an issue. In my experience-the majority of dust, dirt, etc, comes in from the nut opening, and does indeed get past the ball cup. I’ve tested this multiple times with the same result. It’s worth doing. I’ll get some photos of the decal covers too. There are also several pro drivers that have posted videos on YT that I’m aware of as well. I’m almost positive Adam Drake has. And he’s ran Mugen foreverrrrrr.. Which is what this car is.
Finally-big parts… Starting to look like something again…
higher quality pipe hanger from J&T Bearing Co.. The factory ones are almost always trash, and this unit is strong AF, while providing the much needed flex required to keep them from snapping off..
Yasssssssss!!!!!
The Carbon Fiber stone guards are from Protek, and are at least slightly higher quality than the Factory Team units… If those are even available anymore..
On to the radio tray. Get her buttoned up, and installed.. NitroPro or nothing!!!
Factory Team quickchange engine mount. I’ll install some Tony’s Screws when the motor goes in after mock-up is done. No sense in giving unnecessary wear with the ball driver.. and the LAST place I want garbage screws is holding my motor in.. Mugen gray fuel line, and the obligatory Littlemotor custom fuel tank pull..
Tossed in a couple more Tony’s flatheads, and Ultimate countersunk washers for the fuel tank isolators/mounts, and chucked the Buttonheads, and cheap washers in the ever growing ziploc of spare/garbage hardware..
I’m SHOCKED at how this thing is looking at this point…
Snapped a pic, and texted it to myself before I toss this in the trash.. Because caveman..
And NOW…..
I’ve been a big time Picco guy for DECADES… This right here has been in the works for a good minute, and is the majority of the reason that I drug my feet on driving this buggy… Plus that Reds motor that was in it, was actually destined for my Tekno buggy that I recently was able to pick up..
This is a step above the engine I had PLANNED to buy for this RC8, but I was able to get a SMOKIN’ deal on it.. It’s a super nasty 5port Picco P3TX. Japanese blue seal front bearing, Swiss Ceramic rear. Diamond Like Coating crankshaft, that’s been drilled, and silicone filled. Also been massaged, lightened, and counterbalanced. The intake timing is killer out of the box on this bad MF’er, and the exhaust timing is flat out nasty as well. Turbo head button, 7, and 7.5mm venturi’s, and a gorgeous lightweight, reduced CG cooling head. Also the latest/greatest Picco 3needle carb, w/short needle. I absolutely LOVE a Picco carb.. I went ahead and grabbed a spare billet rod, some extra exhaust springs, and rod circlips. I did grab a crazy rowdy 2166 pipe, and manifold for it as well, but if I can come up with a medium length hardcoated header-I intended to run this hardcoated Hipex 2135 pipe I grabbed for it a few months back.. The mock up for these photos will be with the Reds 2113 pipe as the body will fit the stinger location. I already am fairly certain that neither my long, nor my conical Hipex manifolds will put it in the correct location..
Looks sooooooo good….
