Like brand new money…
View attachment 200173View attachment 200174
DEFINITELY these guys… Even AE’s diff cups are hard…. These see lots of action through routine maintenance, but more in terms of setup changes with anything 1/8 scale ending in *uggies-not just nitro stuff.. I want good hardware here especially.
View attachment 200175View attachment 200176
Allllllllll those baby m3x3mm set screws FOR SURE..
View attachment 200177View attachment 200178
DONEZO.
Some more upgrades in the pillow ball area.. (1) pack of two Factory Team aluminum/hard anodized PB’s.. Steel stud, aluminum balls.. I like to run steels in the lower arms, and ally in the uppers. If ya REALLY wanna get jiggy with it-grab the titanium stud from T-Work’s for more weight savings… Keep in mind though-not nearly as strong as the steel stud being the same size.. Just the balls is perfect for my needs.
The fun part is assembling them so they don’t come apart/fail on ya, while also not scarring up your nice new, ultra slick anodizing.. I use standard blue Loctite stick (my go to for EVERYTHING metal to metal in 1/8 off-road, and with no failures in 35+yrs [regular blue liquid before the stick came out over 20yrs ago]), clean the threads with brake kleen, or acetone, then assemble finger tight. After this I insert my 2.5mm driver into the steel stud, and wrap the pillowball in my leather belt. Grab the belt with small Channellock’s, and turn the DRIVER to around 5 ft/lbs.. No-Red is not necessary. I didn’t get pictures of this-as it already takes (3) hands to execute this particular trick lol..
View attachment 200180View attachment 200181View attachment 200182
More upgrades, setup changes… Going with universals, and ditching the “kit” offering CVD’s. My track isn’t a blue groove, ultra silly maintained, hard packed, and sugared clay surface.. CVD’s are known for working well on those surfaces, and for causing the car/truck to be more inclined to catch a rut, bump, or steer itself down a rougher track as compared to the much free’r action of the lighter, FAR less maintenance requiring universal joint/axle setup. This is also way more prevalent in buggy, but still notable in truggy as well.. I have a pretty decent CVD building regiment, and have used 100% graphite with mine for years, and it works very well, but still not as optimal as a universal for what I’m doing.. This requires some bearing, and spacer/insert changes too.. Also, you cannot do this if you’re running narrower 15mm out drives in the front with this buggy. Just an FYI-so if that’s you, and you’re doing this-getcha some proper 17mm B4 units. You can also toss a pair into the rear, but it’s not needed. Some do it for piece of mind.
View attachment 200183View attachment 200184
Man… I sure do appreciate my Tekno’s anytime I work on anything else.. a 3mm screw is your shock standoff in 99% of every other 1/8 buggy, and truggy out there… That’s just crazy to me.. regardless-I’m a super happy to ditch the grade 5 m3x25mm SHCS in favor of 12.9 at least.. Also, running the Ultimate Racing m3 “cone washer” on the back side for more clamping force than even a flathead, and countersunk washer. Strictly for bling-a-licious effect; some 1up Racing m3 “dark blue” aluminum Nyloc flange nuts.
I’m about to give myself a bunch more work right here…. IDIOT…
View attachment 200186View attachment 200187
So as I was rinsing off the garbage black “kit” grease to use my tried, and true CMD #3, the Naphtha actually ran down the cup, over the out drive, and into the METAL shield for two of the diff bearings.. I thought they were rubber shielded-both sides… Thanks Associated… My dumbass fault for not LOOKING first..
Robbing Peter to pay Paul.. I’ll order up (4) more 8x16x5’s from either J&T, or Avid..
View attachment 200188View attachment 200189
Not much in the way of hardware here-but a pretty damned major upgrade I’ve been sitting on for a hot minute; VRP 20 hole bypass pistons… I’m stoked!
View attachment 200190View attachment 200191View attachment 200192
