O.S. 12cv engine
Coos Bay Oregon
  3. Crawling
  4. Boating
I was digging through my bins of nitro engines and came across a froze up O.S. 12cv engine. It doesn't have a backplate or carb. Does anyone know anything about this motor or what vehicle it could be out of?
Thos os.12 were in just about anything .... and that is the iconic head of the late 90-s early 2000s .....i ran these motors in a NTC3 , I know you could buy just the cyl head itself too as a "upgrade". As far as backplates they had pull starters on them .... they had block off plates for them so you could use a starter box ... and most of them used rotary style carbs .... was a very good running motor back in the day ......
Does anyone know how to take this part off? I don't know if it threads on or is just rusted onView attachment 209765
i know alot of the clutches for the cars/trucks used a nut to hold the flywheel onto the crank ....... but they are also a tapered crank/ flywheel so it did not take alot of torque to hold it onto the crank.... and if memory serves me correctly i also think they were reverse thread for the crank nut ..... but i could be wrong .... its been atleast 15 yrs for me to touch a nitro motor
The flywheel was on backwards to what I am used to and it doesn't have anything to grab onto either
I don't see where a pull start would crank the crankshaft.🤔 what other ways could it be started?
I don't see where a pull start would crank the crankshaft.🤔 what other ways could it be started?View attachment 209796
yeh that looks like a bump start version ..... normally for a pull start version there is a little dowl on the crank wrist pin that is just a tad smaller than the wrist pin itself ..... that cogs with the pull starter
Is there a way that I can start it without the bump box or changing the crankshaft?
not that i am aware of ......... either has to have the pin on the crank or a way to spin the crank , like a bump box
That has to be a bump start type engine... I am not familiar with that engine so I dont know how to pull that collar off the crank snout. Is that a nut inside of that collar piece? If not then you need like a clutch type tool that would hook that thing and press on the crank while pulling it off the shaft savvy?
I got it off of there. It was stuck but it was threaded on
