No response to throttle
revo jake
Hay guys bought a used revo 3.3 and dosnt respond to transmitter signals only steering it can correct it if i manually offset it but seems like its ignoring the transmitter I've tried switching the wires from steering and throttle but it still does the same thing but it knows idle cuz he corrects it is it a transmitter problem or receiver cuz servos are good
So are you saying the throttle will move with the trim button? If so, it sounds like the potentiometer for the trigger went bad. It this a nitro RC? You mention idle, but it's hard to understand what you are saying.
Yea sorry its a revo 3.3 yea when i turn on the receiver the throttle corrects itself but theres no response to the transmitter. The steering works fine.
So when you swapped wires, I assume the throttle worked with the knob, but the steering wouldn't work with the trigger? If so, bad trigger in transmitter.
sound like radio issue not receiver.
so steering works
throttle does not
when you swap channels steering dont work via throttle lever?
throttle will work via steering wheel yes
Ill actually try the wire switching again cuz the throttle still didn’t work but the steering worked with the transmitter wheel. i dont know I might have had the wrong wires I’ll watch more videos and see but I'm not home today ill try it tomorrow.
Thanks alot guys
I'm pretty sure its the transmitter too cuz its kind old already ill try binding it with my friends transmitter
Thanks alot guys
Does your friend have the same transmitter? If not it may not be able to bind.
If you end up needing a new one you might want to look at the Flysky GT3b
Yea I tried switching wires again and yea its my transmitter. i have it in pieces now looking for a disconnected wire butit looks fine. Its the old style without bluetooth so it’s different from the inside. I've been thinking of swapping for a newer one anyway thanks again guys means alot
Channel one is steering channel 2 throttle. Did you check servo, maybe servo died or gears stripped and that's why not moving throttle
The servo corrects itself when he turns on the car. And he has swapped cables on the Rx and found out it's the Tx. Problem solved.
