Yeah mine has one for if it goes pit of range/battery. But what I mean is that if it's running out of fuel it starts yo rev really high and run really lean and there isn't much I can do but just let it red line until it hits something or shut off. That's why I want to see if there is a fail safe so that if it happens it does go full speed into something and wreck the car
Then you seriously need to adjust your brakes. It takes VERY low force to shut off a .21-.28 nitro engine. My high end race .21 engines can be shut down at idle with my FINGER against the flywheel. If you experience a REAL “runaway”, good luck lol… You’d better have your shoe, the rubber stop end of your tuning driver against that flywheel, or a leather thumb, and just plug the exhaust. If you do plug the exhaust, be prepared to replace that glow plug, because you likely just ruined it. Personally I’d rather have a burned thumb, than sling a rod at 60,000rpm, and have a $550 paperweight.. Even my old modified race .28’s (yes, they used to race .28’s in truggy, I’m OLD.
) were able to be shut off the same way. Dragging the flywheel is, and always has been the smartest method to shutting off a .12-.30 glow nitro engine. Pinching the fuel line is for newbs, as this runs it lean, and plugging the exhaust can kill your plug as I said above.. I always dial in my failsafe correctly between my Transmitter, and Rx as you’d be a fool not to utilize it, but it’s not the be all, end all that it’s made out to be, and things happen. I’ve never run an external “fail safe” aside from a few small rubber bands to pull the carb closed mechanically. The issue with this, is that your bands need to be strong enough to overpower the servo if you lose electronics power, or communication, and many of todays servos require quite a bit to overpower manually., but it’s not impossible, and I run good servos so it’s not a problem for me. For the few seconds your engine goes lean when you run out of fuel, you should ABSOLUTELY be able to apply the brake with your radio, and have no issues what so ever as it leans out, and dies. If you DO have problems, then your brakes are definitely not properly adjusted. Also, as stated a couple posts back-if you’re motor is revving to the moon when it goes lean-it’s lean already, and you need to do some work on tuning your engine. First BRAKES. You need to be able to control your vehicle. Then learn to tune it properly. If it’s not right, keep tuning until it IS. Don’t drive it lean as a mofo-you’ll sling the rod right out of it, and then start hating on nitro RC’s because you had a bad experience that you were literally responsible for lol.. In all honesty, what you SHOULD be doing, is as simple as being responsible with your fuel level. This is hobby grade stuff at the level of having a nitro engine, and this is a real simple lesson to learn. I’ve been into this since the mid ‘80’s, and have yet to have my brakes not hold my vehicle if I didn’t stay on top of my fuel level. Good luck.
