When I give it full throttle or even half the nitro car just bogs. does this mean there is too much fuel or not enough? rich or lean
thanks
(btw i am new at this stuff)
Your HSN is too rich lean it out a 1/8 turn at a time and keep running hot passes while doing it you will start noticing improvement once you don't notice any more improvement back it out rich a 1/8 and roll with it.
It could also be an extreme lean problem. If it's spitting fuel out the exhaust when it boggs, then it's a rich problem. If not, it may be you're to lean on the HSN.
I may be wrong here... But when I've had tuning probs I was alwayz told to turn da HSN fully to da right (richest point) then turn 4 full turns to da left. Dat should give u a pretty decent starting point... From there adjust 1/8 turns richer or leaner as needed... Hope I explained dat right...
My nitro rc bogs at full or half throttle. I am still new at this rc stuff and I have a kyosho drt.It is releasing nitro from the exhaust, what should I do.
