tricky1400
hi i am new to nitro radio control and hope someome can help me with a problem i have with my BSD nitro assult buggy .
i have just run it in and have run it with another couple of tanks of fuel and everything was going great . . . then tried to start it over the weekend and it revved really fast making all four wheels rotate .
i first tried to slow the idle with the idle screw , as i turned the idle screw anti clockwise the engine started to slow down , but as i kept turning the idle screw the engine cut out .
the car wouldnt start again until i returned the idle screw clockwise again , it then started but was revving high again so started to turn the idle screw out again and the same thing happened , engine cut out again .
the car will start and run but only if it revs high and the wheels turn .
i know that when i apply the brakes the carb has to be open at least 1mm to allow the engine to run but if i put the brakes on or put the car on the ground the engine stops
the mixture screw has been turned in half a turn per tank full while running in as per instructions and its at 2 and a half turns now , i have tried increasing this to 3 and 3 and a half but it doesn't make any difference
would really appreciate some help with this
thanks
thanks
