- Thread starter
- #21
Yea sounds like a plan. Never wrenched on anything less than my Pontiac aha. Forgot to ask, what kind of lube/grease for everything? Do I need to go grab some special purpose stuff at a hobby shop or ?
if its a 2.5 i would put a lc3 glow plug in unless you are running higher nitro content >25%
and for an extra couple of bucks i would put in a 2070/2075 servo for steering for around $23 it is a marked improvement over the 2055
Cool!
Do I need this dif oil or is it a good idea?
Well I started the tear down and cleanup. Cleaned up the steering arms, re-greased the joints, removed the broken servo. The diff doesn't seem too stiff, much smoother than the rear; so I am gonna put off the tear down of the front diff till I make sure the engine works. Don't wanna waste time!
Got the engine out of the truck. The fly wheel won't budge at all. Going to go get some fuel tmrw and pour some in and let it sit like you said Rolex. Hopefully it frees up ?? I'm sure it has never seen a drop of after run oil from previous owner. Any insight on the engine?
And I bought a glow igniter kit for $20, do I need it? This truck has the electric start. Not sure if i do...
At that point, its cheaper to just buy the motor complete or just get a 3.3 for not much more and put your carb on it!
Either, your going to be into it at around 300 with a truck and a roller or your going to be into it with your current truck at around the guys asking price of his used one!
