New os max .21 xz-r on road won’t start
street silence
RCTalk Champion
I’ve tried air drying the engine it’s not turning the flywheel. I have a Mugen pro starter blll. I’m going to keep trying I had turned it ones but for a little bit I have the flywheel facing away from me. Could it be the wrong direction? I am using a pair of wolf pack 4000mah. I’m going to try air drying for a longer period of time. It gets stuck on TDS
Yea ,new engines have a very tight pinch ,especially a high end one such as OS ,have you tried
to loosening up the glow plug up a little to relieve some pressure?
Yea, I been taking out the engine haha just to turn the flywheel back to BDS. It does turn by hand with force but not with the starter box it’s going to turn just not wanting to turn rn on me
*BDC
*BDC
Yea ,its tough to get them to start with them having a tight pinch an not heating them up
to a proper temp as I don't think a hair dryer will reach to the 180 deg. to expand the sleeve!
Dryer for sure not going to do it
I got a little more fuel on the hose with a full charge battery’s before they starting draining. It’s not wanting to turn the rubber wheel on my box when I press down on it. It does make it easer with a heat gun
Make sure the rubber wheel is not rubbing on the chassy ,some times you have to shift the chassy
over a little to find the right spot on the flywheel!
On my box ,I don't have my chassy pegs set right ,so I have to shift chassy around a little to get
it to grip the flywheel!..👍
