WHAT IS THIS ? Not MT. Is this MUD TRUCK ? never seen before . LOL . Must be FUN at Mud. Find mud area is hard sadly where i live.
Product Details
In The Box
- (1) Losi® LMT 4WD Solid-Axle Mega Truck
- (1) DX3™ Transmitter
- (1) Battery Foam Block Support
- (1) Zero Degree Rear Hubs
- (1) Instruction Manual
- (1) Product Card
- (4) AA Transmitter Batteries
Needed to Complete
- (1) 2-4S LiPo Battery with EC5 or IC5 Connector
- (1) Compatible LiPo Battery Charger
Ready-to-run Losi® Mega 4WD trucks with officially licensed Bog Hog and King Sling bodies offer a truly unique driving experience. The new platform gives you what you really want — it's overpowered, overbuilt, and ready to throw mud everywhere!
- Officially Licensed: Designed to look and perform just like the real trucks
- Best Power-to-Weight Ratio: 4S-capable powerplant
- Overbuilt: 1/8 scale metal drivetrain in a 1/10 platform for extreme durability
$649.99
https://www.horizonhobby.com/product/lmt-4wd-solid-axle-mega-truck-brushless-rtr/LOS04024.html
Features
- Officially Licensed King Sling and Bog Hog Body
- Officially Licensed D&D Paddy Tire and Wheel
- Spektrum™ Firma™ 130A Brushless Smart ESC
- Spektrum™ Firma™ 3668 2800Kv WP Brushless 4-Pole Motor
- Spektrum DX3™ DSMR® Smart Transmitter
- Scale Solid-Axle Housing
- 1/8 Scale Metal Drive Train with CUSH Drive
- Powder-Coated Vertical Plate Chassis
- New Flip Top Cage
- Long Travel, Oil Filled, Coil-Over Shocks with New Shock Shafts
- Adjustable Servo Saver
Mudslingin' Mega Truck
New, ready-to-run Losi® Mega 4WD trucks with officially licensed Bog Hog and King Sling bodies deliver an experience unlike any other Losi product. Mega trucks resemble monster trucks but use a specific size of tractor tire that allows them to tackle mud bogs, make large jumps, and pound through the nastiest terrain. The Losi Mega truck is a combination of everything drivers want — it’s overpowered, overbuilt, and ready to throw mud everywhere!
Based on the bar-setting LMT chassis, the Losi Mega truck is focused exclusively on the thrill of "sending it" with insane power. It looks just like the real thing. It’s just as impressive as the real thing. And you can drive it just like the real thing! When top real-world drivers Dennis and Weston Anderson get behind the wheel of their 1500+ horsepower, full-sized Mega trucks, they set records for jump distance, lap times, and smiles in the crowd. Whether you’re driving the Bog Hog or King Sling radio control Mega truck, you have the same potency to do insane backflips, skim across the deepest mud puddles, and jump higher and farther than ever before, just like the Andersons.
Losi worked exclusively with the biggest names in the sport, Dennis Anderson and his son, Weston, to reproduce the body design and graphics details perfectly. We even include a driver insert with a safety seat, headers, and a fuel cell to make this truck look as realistic as possible.
Shared with the Losi® LMT monster truck, the 4-link, solid-axle design with an internal metal drivetrain can withstand constant abuse. The differential is also sealed to hold oil that can be changed to different weights to tune your truck for your specific needs. Adjustable caster and toe also let you dial in those little details that make a big difference in performance.
To handle 3S and massive 4S power, we include three metal-geared, sealed differentials tied to a unique CUSH drive technology. The CUSH drive technology uses rubber elastomers on the main center drive gear to act as a torque dampener and protect the drivetrain when it experiences sudden impacts — without losing any power output like a traditional slipper.
Powder-coated just like the actual trucks, the twin vertical plate chassis provides superior strength and gives you multiple setup and tuning options. For example, two battery mounting options allow drivers to use a "shorty" pack for a lower center of gravity or run a full-size pack to maximize run time. The chassis plates also provide tuning options for those who want to mount the shocks to the lower 4-link bar (sold separately) for the ultimate handling characteristics.
New Flip Top Cage
The new, flip top cage hinges in the front, allowing for shorter front chassis plates with less overhang to accept more body options. The cage also makes it easy and convenient to change batteries or access your electronics if needed.
The 6.25 inch tall tire has an aggressive deep tractor tread to get you the most traction in the mud. The wheel is chrome-plated and features a replaceable center hub to add durability. Optional offsets are also available (sold separately).
Smart Technology
The 4S-capable 130A Spektrum™ Firma™ Smart ESC provides a higher power-to-weight ratio than many other RC vehicles. To make optimum use of the Smart Technology, just download the free Spektrum Dashboard app to your mobile device and add the BT2000 Bluetooth Module (sold separately) to your transmitter. Then, with no additional sensors or modules, you’ll be able to use the transmitter’s Smart ESC compatibility to receive important telemetry data in real-time, right at your fingertips.
New Brushless Motor
Mega trucks are powered by the new Spektrum™ Firma™ 3668 2800Kv WP brushless 4-pole motor. The lower Kv and longer motor provide more torque for mudding action.
Long travel, oil filled, coil-over shocks with rubber bump stops are fully sealed and tunable to optimize performance. The new shock shafts have more thread engagement into the shock rod ends for added durability and now capture the pistons using locknuts. The new shock spring cups also feature a removable shock shaft guard to keep any debris away from the shock shafts for extended O-ring/bushing life.
The adjustable, servo mounted servo saver allows you to adjust the tension on the servo saver to maximize the balance between steering performance and servo protection.
Officially Licensed
Mega trucks have taken extreme motorsports by storm. These 1,500 horsepower trucks are built and designed to take on the nastiest terrain, from deep mud pits to big jumps. The first family of professional monster truck drivers, Dennis Anderson, and his son, Weston, are trailblazers in Mega trucks. Weston currently drives Bog Hog while his father drives his custom-built monster mud truck, King Sling.
Product Specifications
| Approximate Assembly Time | Less than 1 hour |
| Body | King Sling and Bog Hog Replica, Painted and Decalled |
| Brakes | Integral with ESC |
| Pinion | 14T |
| Scale | 1/8 |
| Ground Clearance | 2.0 in (50.8mm) |
| Internal Gear Ratio | 10.16:1 |
| Motor Size | 3668-2800Kv |
| Product Length | 21.25" (540 mm) |
| Suspension | Solid Axle 4-link |
| Wheel Width | 1.3 in (33.0mm) |
| Connector Type | IC5 |
| Battery | Sold Separately |
| Front Track | 13.25 in (336.5mm) |
| Vehicle Size | Standard |
| Inner Tire / Outer Wheel Diameter | 2.6 in |
| Product Width | 13.25" (337 mm) |
| Radio | Included |
| Technology | Smart |
| Charger | Sold Separately |
| Differential | Fluid Filled, Bevel Gear |
| Receiver | Included |
| Shock Type | Aluminum Oil Filled Coil Over |
| Power Type | Electric |
| Gear Pitch | 1.0 MOD |
| Servos | Included |
| Ball Bearings | Full Ball Bearings |
| Chassis | 3mm Twin Vertical Plate, 6061-T6 Aluminum |
| Completion Level | Ready-To-Run |
| Drivetrain | 4WD |
| Drive Type | Forward/Brake/Reverse |
| Product Height | 11.5" (292 mm) |
| Tire Compound | Firm |
| Wheel Hex Size | 17mm |
| Rear Track | 13.25 in (336.5mm) |
| Speed Control | Included |
| Wheelbase | 15" (381 mm) |
| Final Drive Ratio | 18.76:1 |
| Motor Type | Brushless - Sensorless |
| Product Weight | 9.6 lb (4.35 kg) Without Battery |
| Tire Tread | D&D Paddy |
| Vehicle Type | Monster Truck |
| Water-Resistant | Yes |
36 size motor only, hmmmmm
wish they had 40 size in this , like 4068 2650kv
