new engine problem
[email protected]
belgium
I have purchased a new engine 17x2 toxic by carson,
when I accellerate I have to push my car to get him going.
is someone familiar with this problem??
grtz
You need to clear this up. It's posted in the Electric forum, and you're calling it an engine. So far I'm clueless about your problem.
same happend to my mini-t the brushes are binding pull the brushes and clean them with an eraser then it should go fine
Did you break in the motor? on a brushed motor if you let it run for a little while lower voltage it allows the bushes to seat with commutator and allow better transfer of electricity, also make sure your brushes move freely in and out of the brush hoods if they are binding it won't allow the springs to push the brush in and make good contact, its also a good idea to put a few com drops on the commutator to help in the break in process..
and it make this high pitch noise, is that the motor or the esc?
the motor goes slower then faster,...
the speed fluxuates
