Need Some Painting Tips...
ZaneC
RC Showcase: 1
Topeka, Kansas
  3. Crawling
  4. Scale Builder
  5. Flying
Hey y'all. Here soon, I'm gonna be building a SCX10 III Kit, and the body I'm choosing is the Pro-Line Ford F-250 half cab. I'm gonna be painting it white (after my Dad's truck), but I'm wondering how to back it?
How do you back white? That's the big question.
Three more questions:
1: You just degrease it (what brand works best, or does that matter?) and wash it with soapy water, right?
2: What is the best stuff to mask off parts of the body with? A top 3 list would be helpful.
3. Can you just use little scissors to cut out bodies?
I usually paint a coat of white, then silver, then black. I kinda like dyratrax black as it dries flat and looks more scale. Be sure to let dry in between and use a hefty coats before black.
Blue dawn is my soap of choice. If using masking tape, ideally cut it before it's on the body to prevent scoring. Also store tape on a clean paper plate and in a bag when not in use to not contaminate the edges.
@WickedFog has a good tape for clean edges.
You don't have to degrease it but you do wash it with soapy water, and I would use liquid mask for as masking tape tends to leave lines .
Will it darken the white paint at all?
I'm in for the tips. I'm confused if you are doing a white truck, where the black comes into play?
Also, just realized, now that I have an air compressor, I need to get a paint gun for some attempts at better results and detail.
I usually back white or any bright color with silver. Helps make the color pop a little bit more. You can back the silver with black if you want, but I usually don’t though because I’m cheap. Once the silver is sprayed on, you won’t notice any changes to the white color by spraying another color over the silver.
Spray cans work fine unless you’re doing intricate airbrush designs or painting a lot of bodies. Airbrushes use a lot less paint than a can, so you can make your money go farther in the long term at the trade off of higher short term expense. If you’re just painting a body every so often and doing basic colors/designs you probably won’t get much value out of an airbrush for quite some time.
Side note: Tamiya Pearl white is the best looking white and I will die on that hill 😂
Have you seen proline pearl white? What about faskolor. Faskolor have a red, purple, or blue hue in it. When I finish my proline pearl white on the cen f450, I'll compare it to my old tamiya pearl white f250.
Bit of a pearl white super duty nerd. 🤣😝
Bit of a pearl white super duty need. 🤣😝
If I wanted a red, purple or blue hue I’d paint it those colors! 🤣
I haven’t seen proline pearl white, I’ll have to check it out.
Meant to say proline has a 2011 f25 cab and a 2017 cab in extended cab format, and cen has the f250 and f450 cabs in crew cab format.
My Harley had ghost flames that got different hues (pink red and blue) of pearl so that the flame tips would turn different colors as you walked by it but looking straight on it was red.
It was SO COOL!
The painter did an AMAZING job!!! 😍
Here is the process and supplies you SHOULD use, but not mandatory.
1. Trim and fit the body (mounting hole locations done here too).
2. Sand and smooth the edges, all the way around.
3. Wash the body
4. Mask the entire body
5. If using liquid mask, draw your design on the outside of the body
6. Paint
7. Back your paint
8. Peel the protective film
Trimming
I find it helps to use an ultra-fine Sharpie and trace the cut lines before I start trimming. Sometimes the cut line can disappear in certain light, depending on the angle the body is to the light.
You can either use scissors, or an X•acto to do this. I typically use a combination. Scissors on the things I can get to, straight edges, etc, then use an X•acto on things I can't get to with scissors.
When using the X•acto, you only need to lightly score the line. When doing wheel arches, cut around the line with the knife, then you can use relief cuts to break the wheel arch out in pieces.
Notice how in the pic above the relief cuts try to break the curved arch into straight segments. You will have a harder time snapping the segment if there is much of a curve in the snap line. Don't tug and tear the pieces out. Bend back and forth gently and they will eventually break free. You can do this without the relief cuts, but I find it easier with them.
Once your body is trimmed, put it on your RC and line it up with your wheels. Make sure your steering is centered, and the battery is installed so your RC is at the ride height it will be. Then pop your body mounting holes in with a body reamer.
Put your body pins in and turn your steering and compress the suspension and check for any tire clearance issues. Trim where necessary.
Sanding and Smoothing the Edges
Go around the edges with wet/dry 220 grit sandpaper or enery cloth. Knock out any rough spots. Smooth your wheel arches and radius the corners where the arches transition to the lower valances (areas under bumpers) and rocker sill (area under the doors).
Once everything is smoother, go around your edges with some 400 grit wet/dry sandpaper. You're trying to create a bit if a radiused edge inside and outside the body.
Wash the Body
Get a green Scotchbrite sponge and some dish soap. Wash the body inside and out with the sponge side and some soap, being mindful of the edge of the protective film. Always wash the outside from the body towards the edge so you don't peel the film.
On the inside, after the preliminary wash with the sponge, you can flip it over and use the Scotchbrite to lightly scuff the inside. You should barely see the scuffing, if at all. Do the entire inside, making sure to get into the nooks and crannies.
Dry the body thoroughly with a clean lint-free towel and let it sit for a few hours, or you can hit it with a hair dryer. Be careful. A hair dryer can get hot enough to melt lexan. More air, less heat. Hair dryers can also create water spots if you have hard water 😉
Masking the Body
Once the body is dry it's time to mask the body. You can do this two different ways. Liquid mask, or vinyl masking tape.
One Color Designs
If you're just painting the body one color, you can simply apply your window masks and spray the body.
Simple Paint Designs
If you're doing a fairly simple design using a couple colors, vinyl making tape and using your window masks is fine. Here is the vinyl masking tape I use.
https://a.co/d/7S5I2aM
Liquid Mask
If you're doing a more complex design, liquid mask is much better. For this, you don't really need to use your window masks.
Apply an even coat of liquid mask to the entire inside surfaces or your body. A set of horsehair or "camel hair" brushes is ideal for applying liquid mask. Note: Camel hair brushes aren't really camel hair. It's a combination of animal hair.
https://a.co/d/afuZRLp
Let that coat dry thoroughly. You want it to be clear before you apply your next coat. This can take hours, so be patient. Put your body under an air vent, or next to a fan. You want at least 5 to 6 coats total.
Once your liquid mask is applied, draw your design on the outside of your body shell. Make sure to also mark the window and trim edges, along with any body details like hood vents, grille edges, lights, etc, if you plan on leaving those areas clear, or plan to paint them a different color.
Once all your line work is done, use an X•acto with very light pressure and trim out your entire design. Be careful not to peel up any edges. If you do, you can apply more liquid mask there and let it dry, and recut that area.
Peel the section for the first color and spray. Typically, you want to start with your darker colors and work towards your lighter colors. But this isn't always the best method. If you have to paint a lighter color first, back it with silver before spraying a darker color over it.
Painting
Spray your first coats very light. You should barely see the paint. Make sure to get your mask edges sprayed. The trick is to lightly spray your masked edge, without getting the paint heavy enough to run under the edge. Doing this in two or three coats will seal that edge, so you don't get paint bleed.
References:
Prep - Mark has some great tips in this video. Pay attention to how he shows his method for lining up your window masks perfectly.
Paint and Decals - Again, Mark shows you some more decalling techniques. This guy is really good at applying very complex decals and getting them to lay exactly where he wants them to go.
Liquid Masking - This is a video I learned a few things from. There are other (and better) videos out there, but watch this one too.
