Greywolf74
I'M TO BLAME!
Lifetime Supporter!
RC Showcase: 8
Blade 120SR a good Heli to learn on? I've read a couple people here and there say that it is and i like the fact that its a little bigger than your standard micro. i also like that fact that it has what appears to be JR connectors on the lipos which means I can solder up a parallel battery connector or someone may even make a series adapter so I can charge multiples at once.
Also is the stock TX that comes with it fine for this kit or should I look at the BNF and some other TX (Suggestions appreciated if this is the route your would suggest)?
Any other things I should take into consideration?
