Need help with this engine
cientist8196
i apopogize in advance, i have the biggest cold ever.
i need help putting this engine back together. link is to the video i wanted to post here but it wont upload.
pictures 4 through 7 have the parts roughly in the same position as when they are assembled.
any help is apreciated. thank yo.
Welcome to the site.
Oil the piston and sleeve. Pull piston out, lower through the top of the motor and hook it on the motor. Holding it through the side of the motor, drop the sleeve through the top gently, and let the piston slide in. There may be a marker on the block and an indent in the sleeve so it won't spin around.
From there slide the starter shaft and the backplate lining the notch on the start shaft to the stud on the crank shaft. Screw in the backplate and plop on the cooling head.
Also put the carb and an air filter on immediately. These cars are highly allergic to dust and dirt.
my only problem is really the orientation of the piston. dumb move, didnt pay attention when taking it out cause i assumed it was like the newer one i have where there is a clear way to identiffy. the video explains eveything mutch better.
Not sure if this will help with sleeve orientation, rebuilding mine right now also. I can pop the pull start and stuff back off if you need a pic of the inside also
there is a little pin on the sleeve. thing is the new pistons have a cut and a hole in the comrod that face the front. this one all it has is a hole in the piston itself.
no hole in he rod, no skirt in the piston. every single bit of info i find is on the newer tipe engines, have yet to see one of these in a video or foto or anything. this thing is like 30years old.
Freaking hell. 3 weeks searching for this nonstop and now i just tipe "nitro rc piston orientation" into google and this
shows up. did that countless times allready.
well, problem solved. thank you guys!!!
Much appreciated. I got an hpi 15fe.
Glad you found it, I was going to break mine back down to take pics because I could type how to describe the process lol
That guy knows his stuff and he's funny as hell eh.
