Need Help Finding Parts
KbigO69
Kirbyville, TX
Ok i have a hpi mt and I'm about to get a bulk order of parts. here is the link to all the parts http://www3.towerhobbies.com/cgi-bin/wti0005p?&I=HPIC1556&P=X now what i need help with is which parts i need( due to different choices of same parts) I'm needing the differential shafts on both the front and back( where the dogbones connect to the differential) also needing the bearings on all of it. also i dont know which clutch bell i get. any help will be much appreciated
Nevermind me! Rc is right.
They do make upgrades though that are a little stronger.
Bearings you need and the Tower Hobbies part numbers:
For Replacement Ball Bearings use:
Qty. Size Location Bearing Set Qty.
(4) 5 x 11mm front & rear gearboxes (use 2 DTXC1547)
(4) 10 x 15mm front & rear diffs (use 2 DTXC1595)
(2) 5 x 11mm front hubs (use 1 DTXC1547)
(2) 10 x 15mm front hubs (use 1 DTXC1595)
(4) 5 x 11mm rear hubs (use 1 DTXC1547)
And you are welcome...
