i recently bought a new nitro. I just finished break in but the engine is not running right. when i start it up it runs fine but pnce i start running it and get i up to temperature it starts idling really high when i let it sit. then when i hit the gas it will almost bog and idle normal for a few seconds if i dont apply throttle then start idling high again and will start moving with out me applying throttle. it is also running really hot which i know i need to richen it, but the thing is when i first start it it idles normal so i if i adjust the idle and mixture screws, will it not start because the idle will be to low. any suggestions? thanks
