DubVrC
A buddy of mine had this rig in high school and apparently only ran a couple of tanks through it after break in before he broke a front arm and put it up. It then sat for years until he told me he was going to pitch it. I know right throw away a perfectly good nitro car !!! He's lost it. Regardless i saved this little truck from it's death bed and want to revive it.
I already took the motor all the way apart with the exceptions of the bearings inside. should i also dismantle the carb and/or trans too ?
The engine was pretty clean outside a little rust and gumm.
What if anything should i use to lubricate the bearings inside (I'm cheap i already have synthetic motor oil and Marvel Mystery Oil would either work) if not some other relatively inexpensive option then ?
I plan to seal the engine when i get it reassembled is there any adhesive sealant (cheap) that you guys recommend?
And lastly the radio that he had is broken so i have it running off a futaba i used to use with a little tamiya electric. It seems to move all the servos appropriately but i will no doubt want a better radio at some point. Any suggestions on good radios that aren't out of this world pricey? ( i understand a radio wont be cheap regardless)
Any help would be greatly appreciated I want to get this guy up and running to bash when the weather breaks here in WV
