my mammoth st is making me crazy
speedingbulletbp
Gone - bye bye.
North Dakota
I've been racing my mammoth st in a drag against alot of 3 speed savages and won but my pins on the front of my truck keep falling out I've racing it as rear wheel drive and now its getting worse I've been putting locktight on them too but they still fall off even with the strongest locktight what should i do.?!!!!!!!!!!!!!
:redbuggy: :ha: :angry:
Cover the cvds with heat shrink tubing. It will keep the pins from falling out. I like to use heat shrink tubing with the adhesive inside them. When you shrink the tubing with heat, the adhesive/glue melts and makes it very tough for the tubing to come off.
RULESp said:
Use of Smilies - The a hoot, but when there is a thread full of them it gets annoying real quick, while at the same time slowing the site down. Please limit your use of smilies to 2-3 per thread.
I'm not usually one to complain about spelling and grammar, but I don't have a clue as to what your asking. Also see above for the smilies.
He's right. Mine kept coming out too and I used the big grey heat shrink over the pins and the problem was solved. I liked my ST but I wound up tradin that gem for a STR and never looked back. Good luck. Bigcod
