My Losi LMT build/modification thread
JCsRCcar
RCTalk Champion
Massachusetts
  2. Crawling
Starting this thread to document some of the modifications I have done to my Losi LMT so that those that might acquire one and start looking for ideas might learn from this thread. Here are a few of the modifications that I feel are necessary and should be done right away to thwart off the inevidable shortcomings of this chassis design. They are as follows:
#1, strengthen the plastic axles. Many people just roll with it and replace them with expensive metal axles as they break and that is a good option but if you like money in the bank and are somewhat handy then I suggest you summon the MacGyver in you and try modifying the stock axles instead. There are also a few companies that offer plastic braces but I think I have found a better way. More to come!
#2, Install shock limiting straps. If you don't do this then after a few good stunts or jumps it’s likely your shocks wont be able to keep the heavy axles and wheels in check and they will over extend and break the shocks. This is a realtively simple and easy modification. You can use 100 mm to be on the safe side or 105 mm with some risk to get the maximum travel from the suspension. https://www.amazon.com/gp/product/B01N9KC2HR/ref=ppx_yo_dt_b_asin_title_o08_s00?ie=UTF8&psc=1
#3 Add a front bumper to protect the vulnerable front end. If you don't do this then I guarantee you will smash the front grill and lights in no time. The compromise with the bumper is that it does limit its ability to climb walls and do back flips. There are many Chinese copies of a stainless steel bumper and bars such as this one from Amazon https://www.amazon.com/LuDa-Monster-Vehicle-Assembly-Modification/dp/B0967S223F but the downside to this design is the weight of that stainless steel. Its too heavy and upsets the balance of the car. I got around this by purchasing 1/8” aluminum plate and 1/4” round bar stock and making my own based off this stainless steel version. The aluminum cuts down the weight tremendously and still offers the same protection without the weight penalty.
#4, Upgrade the servo saver. The stock servo saver allows too much slop, and in my experience it wont last long before the plastic wears out and leves you with a sloppy handling truck. Solution is the Treal metal servo saver. This servo saver is metal and still offers protection from impacts to those huge monster truck wheels. https://www.amazon.com/gp/product/B091YHN4WW/ref=ppx_yo_dt_b_asin_title_o02_s00?ie=UTF8&th=1
#5 Upgrade the stock Spectrum servo. The stock servo is like all RTR servos, just adequate at best. My choice is, and will always be, what I feel are the best servos for the money or at any cost on the market, and those are all made by ProModeler right here in the good old USA. The Brushless line of servos are the ones to get. Nothing can touch the qaulity and performance these have to offer and I mean nothing. https://www.promodeler.com/standard I chose the DS845BLHV and I have almost one of every servo this company offers in all our cars now (me and my son) and they are just awesome servos. If you’re not running an ESC with a robust BEC then an aftermarket BEC like this one will not disappoint https://www.amazon.com/gp/product/B002ITEL42/ref=ppx_yo_dt_b_asin_image_o02_s00?ie=UTF8&psc=1.
#6 Upgrade the stock C-hubs. The stock plastic ones are ok but they will eventually break, especially if the temperature outside is cold. Again Treal makes a real nice aluminum one that bolts right up to the stock axles and makes this part bulletproof. https://www.amazon.com/gp/product/B08RXZM36D/ref=ppx_yo_dt_b_asin_title_o05_s00?ie=UTF8&psc=1
#7 Upgrade the stock Spectrum Esc and 3200 KV motor. This motor ESC combo actually works well and TBH doesn't need to be upgraded but I’m spoiled by all my sensored ESC and motor combos, so I like the extra control a sensored motor affords you. For this I recommend either a Castle with 3200 KV and Mamba ESC or the Hobbywing Xerun XR8 with with sensored 3200 KV motor. Dont waste your time with the Castle Copperhead ESC because it’s BEC is not up to a high enough standard in my opinion. I usually go with Castle but I chose the Hobbywing this time just because I wanted to try something different.
More to come with lots of pictures coming.
#1, Fill the empty voids inside the stock plastic axle housings with epoxy. I suppose you could use any decently hard epoxy but I had some leftover floor Rustoleum floor epoxy so I used that. You’ll have to do some careful measuring so that you fill in all the week areas and voids, but not so much that it gets in the way of the axle spinning inside. I think these pictures to all of the explaining. The benefit to this is added weight down low to lower center of gravity, and massively increased strength. It’s inexpensive and it makes the stock axles nearly bulletproof.
That's an interesting idea and looking forward to seeing how well these hold up.
Me too. Being a bit of a mechanical engineer in my career, the design of that axle housing just baffles me. It appears to be designed to fail, and the cost of replacing them seems to affirm that. They are a rather expensive, and very poorly designed part.
I don't see the epoxy adding anything to strengthen the design. The actual failure points will be here...
Awesome work and mods.
If i had the funding, i will make a nitro version and look like it came factory, but i can't nor can i justify cutting up one i paid alot to do that on.
My last one i had a guy had to have one i was halfway done building funded to complete it and he finished the pretty parts.
That was a redcat gp though, not a 600 dollar lmt.
If the pictures below I took the original RCmart stainless steel bumper mount and traced it onto 1/8” sheet aluminum. I then cut some 1/4” aluminum rod to the same length as the RCmart bumper rods, drilled them, and tapped them to accept the screw. The final touches were wet sanding them with 600 grit and a little polish to finish them off. They look just like the original only they weigh much, much less. You can also see the shock limiters and ProModeler servo.
In this picture I had originally tried to make the brackets out of ABS and although they came out nice they didnt last after the first big crash.
As you can see the Treal C-hubs are a nice upgrade and they will bolt right up to the stock axles but the fit is tight.
If the pictures below I took the original RCmart stainless steel bumper mount and traced it onto 1/8” sheet aluminum. I then cut some 1/4” aluminum rod to the same length as the RCmart bumper rods, drilled them, and tapped them to accept the screw. The final touches were wet sanding them with 600 grit and a little polish to finish them off. They look just like the original only they weigh much, much less. You can also see the shock limiters and ProModeler servo. View attachment 145813View attachment 145814View attachment 145815View attachment 145816View attachment 145817View attachment 145818
View attachment 145819View attachment 145820
As you can see the Treal C-hubs are a nice upgrade and they will bolt right up to the stock axles but the fit is tight. View attachment 145822
My issue with the axles is where the lower trailing arms attach. After a few good jumps, the axle snapped where the lower bracket is attached. I have managed to temporarily reattach it using a hard nylon strap, but I also tried to be proactive with the other three by using a wider tie wrap to add pressure in that area where there is none. I tried just the tie wrap fix on the broken area first, but they just snapped at the pressure of the first landing.
The LMT is still going strong with the stock reinforced (with epoxy) axles (see first post). I was doing repeated four to six foot jumps yesterday and it landed on the front wheels hard a few times. Time will tell but so far this has been an easy and worthwhile modification. If it eventually breaks then I will let everyone here know and probably go aluminum but so far so good.
any further update?
Axles breaking on the LMT platform has been an issue with those trucks since the beginning. Supposedly they put out a revision that used stronger plastic. Apparently not.
They didn't change the plastic used but they changed the mold to add webbing inside the housing for strength. They also added a screw to the face of the axle cover near the lower link mounts which are famous for snagging things at WOT and imploding housings. The only way to get around blowing housings out in the LMT platform is to go with aluminum housings. Once you go with aluminum housings, 15 other new weak points introduce themselves and start breaking instead. LMT's are awesome, don't get me wrong. But the axle housing design is whack (lower links hang way too low).
Also, another less frequently discussed bug in their design that irks me to no end is the angle at which the servo sits on the front axle…if you have a head on collision with any object at speed, you’re chipping a tooth on your servo gears. No matter how much you spent (or overspent) on your servo and no matter what servo saver you've implemented.
I’ve been through more axle housings and servo repairs to my MKS 550s than I would like to admit lol.
My son lost interest in RC some time ago so I sold most of his RC cars and since he was out of the game there was no reason for me to keep the LMT, so I sold that and all my other Traxxas RC cars too. It was a great and fun monster truck and the axles never broke. Other items did break like end links and a gear but were easy to repair. The Losi LMT is not for the enthusiast that wants rock solid reliability and it is not cheap to keep running for sure but it is a unique and fun RC for doing stunts and crazy jumps.
Recently though my son decided to get back into RC, but this time he wanted something more high end and race grade. I purchased him a Tekno ET410.2 race truggy used from the local hobby shop for Christmas and he loved it. I was so impressed with the qaulity of the Tekno that I purchased a Tekno MT410 original monster truck kit (unopened) from Facebook marketplace for both of us to build together and he built about 90% of it with my supervision. He was so impressed with that kit that he saved up his money and purchased a Tekno ET482.2 kit and he built that car all himself. Now its middle of winter and its too cold out to run RCs so we are waiting for April when the weather hopefully gets RC friendly, probably in mid April. This is it for RCs though as I’m not spending any more money and with the Tekno brand I think we wont need to. We have a small thread on the Tekno forum here. https://www.teknoforums.com/threads/new-to-forum-with-tekno-mt410-et48-2-2-et410-2.3434/#post-26663
View attachment 218427View attachment 218428
Awesome purchases. I think my Tekno's are a bit more durable than Arrma, but both are better than the best that TLR has to offer. With the Tekno you get both precision and durability. Arrma is just a sloppy tank. Lol I have 2 Tekno, 1 Arrma and 4 TLR, plus some other brands for reference. I've been impressed with the mini LMT though. It has taken a lot of abuse before becoming undrivable. I have a common failure point amongst most vehicles, apparently due to my driving style, which is melting bearing retainers. Hubs, diffs, and I've actually had 3 wheels melt off. I change bearings out about every 20 battery packs, with all different brands, and they typically feel smooth when removed. I think it has to do with tire selection and mass mostly, except for the lasernut, which melted the stock wheels and then hubs. Beware of the limited rear driveshaft clearance on the MT410, chassis flex without upgrades will take out the rear diff quickly.
I made sure there wont be much chassis flex on my MT410, so hopefully the rear diff that is known to pop out wont be an issue.
Full thread is here. https://www.teknoforums.com/threads/new-to-forum-with-tekno-mt410-et48-2-2-et410-2.3434/
Nice! When i built mine i never installed the stock front, center and rear braces because i already bought full aluminum upgrade pieces. I still couldn't keep the bearings in, so i ended up replacing the diff housings with aluminum. Problem solved, i hope. I've only been able to run 4 packs through it since then though. You can kinda see the the braces here. Guess i don't know where the pictures of the others are.
Looks very nice. I considered the aftermarket aluminum braces (I think it was MC2) but they were too expensive and when you look at 1/8th scale Bashers like the ones Aarma or Traxas make you see that often times they connect the from shock tower to the rear shock tower with a brace so I bought some inexpensive aluminum dowel and machined it to fit myself. Doesn’t look as good as yours but it does seem to make it stronger so I consider that a win.
