Well, sl0eg1n and I broke down and got ourselves each a Mugen MTX-4. Are we happy with it? Well ... hard to say. Haven't raced it hard yet but here's what I think of the build ...
Hits
This was an easy build. Just didn't like jumping from bag to bag for parts. The directions were mostly designed for most of us men ... follow the pics
If you take more than 10 hours total to build the car up to a roller configuration, you are really working at a snail's pace. That's how easy it is. Just turn on the TV and start building. You'll be done in no time.
As I was building the kit, I couldn't help but notice how similar it was to the serpent 710. The laydown steering servo design, adjustable front and rear belt tensioner, steering ackerman, hingepin layout ... all reminiscent of the 710. The more I look at it, the more it will remind me.
The plastic parts were a disappointment. Yes, plastic will flex and bend. This is good for the arms so it won't break right away but for structural bracing to be flimsy as well? It allows a lot of torsional flex. The chassis is pretty much the standard 3mm thickness but seems to be more flexible than the ordinary.
I am sure more things will come to mind but here are the pics of my build. I did skip a few pics in he process but that's because I got too involved to remember to take them. Maybe next time ...
When outdoor nitro touring comes around, there will be even more to write about. For now, I can only really comment on the build, not on the car in a race situation.
I also forgot to mention that in the absence of the servo arms, I went to my LHS and picked up the Racer's edge aluminum servo arms. These arms have very small holes and will not fit the screws provided in the kit for the linkage screw mounts. I had to drill and retap them in order to be used. I utilized a nylon locknut on the opposite side of the screw to keep it from backing out AND allowing me to loosen it enough not to have the collars bind but still keep the screws from vibrating loose. For now they will stay annodized. When I get the urge, they will be sandblasted and left in raw aluminum . I don't like annodizing ... lol. Makes the car look like a color wheel after a while. Keeping it simple, just as I do with all my cars.
Front oneway
Rear Gear differential
Front bulks and midpulley mounted on chassis
Rear assembly, radio brace and sidepulley mounted
Completed unit
Hits
- Lower CG
- More adjustable design
- simple build
- redesigned tank
- Redesigned battery pack receptacle
- Flimsy rear shock tower
- requires offset wheels
- Rear camber link cannot be adjusted with body still on
- No servo horns included
- Lack of stronger braces (all soft plastic)
- Pipe hanger fell short. Had to bend to reach the pipe. Also in close proximity of midpulley. Hard enough hit and it will contact the pulley. Even in an unbent configuration.
- Spektrum DSM receiver and capacitor
- KO Propo 2363 (steering)
- Futaba 3010 (throttle/brake ... but not for long. All I had left in the pit box)
- Mugen X12 3port
- Maxpower 2615E conical pipe & header
- 1100 Matched 2/3 battery pack
Front oneway
Completed unit
