mt 2 doubts
daniel29
i have en mt2, the front wheels run faster than the rear one and when it gets stuck instead of all wheels move only the front ones move. if anyone can give an advice on how to fix this please help
thank you daniel29
I'm a newb too....but I might be able to help you on this one.
Did you have the rear tires off of your truck? If so...take them back off and make sure there is a little pin in there behind the nut that your wheel pushes on to.
I just got an MT 2 a few weeks ago, and it has been a great truck...but the first time I had the rear wheels off, and then went out and ran, I only had front-wheel drive. I didn't realize the pins had fell out. They are very easy to miss if your new and didn't know they were in there to start with.
Chad
Chad i checked that out and both pins are there and i still have the problem thanls for anyways for the advice.
:jet:
Daniel sounds like chad was on the right track, I believe it is something in the drive line. Check the rear drive cup coming off of the transmission where the brake sits on. There is a small allen bolt type thingy there make sure that is tight. If not this is your problem. I have the oroginal MT and had this problem recently. Funny seeing a truck with front wheel drive only. Ok other possible solutions if that isn't it. Check your diff out drives make sure they are all tight also make sure diff gears are not stripped. Can't think of anything else right now. Could be spur gear related if that thing comes with a slipper clutch.
newnitrofan you were right about the diff it was loose and wasn't grabbing well. thanks for the help.:idea:
:puke:
