Mounting Proline Switch Tires To SC8 Rims ( the easy way )
NFMH
I posted this on the AE forum and just copy and pasted it here. Hope this helps somebody out there who'd prefer to run a more track capable tire. In this thread I use the Switch tires ( 2.2 X 3.0 - Slayer size tires ) but other will be the same ( Bowties, Calibers, etc )
Well I mounted my Switch tires to the AE rims and was relieved to find that it wasn't nearly as hard as it sounded. I did mine a little differently than what you did and thought I'd share.
I left both inserts out, and first glued the 2.2 side and and mounted the beadlock ring. Then I pulled the tire over the rim so that in was inside-out:
Next I took the small foam and stretched it over the 3.0 side and slid it over to the 2.2 side:
Then I made sure that it was seated properly against the 'corner' in the tires, and made sure that it was even all the way around.
Then I slid the blue molded foam on, again making sure everything is straight:
Then I cleaned the bead on the 3.0 side, and flipped the tire back over, then used a Q-tip and isopropyl to clean my surfaces again( I know it doesn't look clean in the pic ). I made sure that the gap between the tire and rim was even all the way around. I ran my tire glue in this slight gap:
And cupped my hand around it for 30 second to set it, then ran electrical tape around it to set it:
I found this to be no harder than glueing any other tire/rim, aside from having to screw all the screws in. Hope this helps somebody out there.
No problem:thumbup1: I really like the look of the Switch tires, I had to have them. Every time I read about someone mounting them up, it was supposed to be a real PITA, but well worth it.
I also read a mild tutorial that was posted, but it seemed backwards to me ( I could see that method being a REAL PITA ). I decided to do it my way, and took some pics along the way to help others who may be interested. I'm glad it helped someone!:D
Did you cut the back side of the tire down or just tuck it under the foam or what?
Nothing was cut to do this. I first glued the side with the beadlock ring on it the outer side of the rim *2.2 side * ), then I slid the foams on, and then glued the back side (the inner side of the rim/tire *3.0 side* )
Yes they are..lol..I just linked this page to you from RCTech:D
Sorry I haven't responded, I was gone for 4 weeks.
The only other non AE wheels available for the SC8 are made by DE racing:
DE SC8 Rims
As far as the Proline tires go, as long as they are a 2.2 x 3.0, they will work.
